Problem with Multiple Converting
    I tried to convert 20 mp3-files 196kb files to 128kb mp3 file. After 1-2 files it stops and it has just converted 2 files.. could someone help me ? thx
    Can you explain 'stop' a little more - dose it crash or just end?
      it crashes, and one or two of the 20 files are completly and without errors converted, but the other 18 are not.
        As a test try to convert them to wave (then delete the wave files), it will tell you if it is the reading, or writing of mp3 files that is crashing.
          mp3 -> wav works fine
          mp3 192 -> mp3 128 doesnt work
            Have a look un Support >> dMC
            There is an older version of Lame you can install - your machine might not like the latest, other than that - your only option is to go with Blade from Codec Central.
