converting problems!
  • kwanchi
    • Apr 2005
    I bought the registered version of music converter. When I try to convert an MP3 it says
    The CODEC required to compress 'C:\Documents and Settings\Kev\Desktop\atmosphere.mp3' could not be opened.
    Error creating mp3 compressor.
    Please help!
    Thanks :teufel8:
  • Smoggy
    • Feb 2005
    • 120
    Re: converting problems!
    Look in the options menu, make sure (Mp3) Lame is selected in the rip to section.
    Smogg
      Please help!
      Thanks :teufel8:
      Converting to or from mp3?
      Is everything installed to the same folder?
      What are the settings of the input file and what did you request for the output file?
      Mp3 cannot be created for 24-bit files or higher for instance. You have to bring your input file down to 16-bits first, through another conversion.
      • neilthecellist
        • Dec 2004
        • 1288
        Also, if none of the solutions work above, try reinstalling everything to its default locations.
