Problems with codecs
  • Byrangas
    • Apr 2005
    When i download a codec to convert MP3 to AAC, and after i install that, i try to convert one file and the message to codec copyright appears.
    Please tell me what kind of codec i need to download to transform MP3 to AAC format.
    Re: Problems with codecs
    There are two AAC codecs: one for encoding and one for decoding. Make sure you grabbed both of them, as your tags will not be preserved without the decoding codec. Check dMC Configuration (Start --> Programs --> dbPowerAmp Music Converter --> Configuration --> dMC Configuration) to check which AAC codec you installed.
      What is the exact message shown?
