.wav to .rm conversion problem on WinXP SP2
  • Wackmanbluboy
    • Mar 2005
    The title of this thread says it all.
    You cannot convert a .wav (wave) file to a .rm (real audio) file on a WinXP machine that has Service Pack 2 using the dbpoweramp converter. This is a fact, not just my experience.
    Some background - I've got Real Player 10 and the dbpoweramp codec intalled so the codecs are all there. I work on multiple machines so it isn't isolated to just one instance.
    Anyone know why or have a fix?
    Re: .wav to .rm conversion problem on WinXP SP2
    I remember seeing something in the MS KBDB about problems associated with SP2 and Real Media.
    Sorry, I don't rememebr what the workaround was.
    I assume you've installed fresh copies of dMC and the codecs?
    • Wackmanbluboy
      • Mar 2005
      Thanks for the response - Everything is fresh, new machines, new codecs and new installs.
      I just looked on the MS Knowledge base and found nothing. Real Player doesn't really offer support for file conversions so I guess I'm screwed.
      Oh well, if anyone finds a fix please post.
        I know I once posted a link to that problem being addressesd in the MS KB. I can't find it now unfortunately.
        • neilthecellist
          • Dec 2004
          • 1288
          interesting. Is this another one of those faults with Microsucks?
            I think it had somehting to do with the extra security, possibly firewall settings. But I simply cannot remember nor can I find the reference again.
              The work-around is install the DirectShow codec from the beta section of this forum and then install Real Alternative's Real DirectShow decoder.
              Edit: Just notice he's ENcoding, not DEcoding. My bad.
                He's converting TO .rm NOT FROM .rm.
                • adaywayne
                  • Nov 2004
                  • 383
                  Which is not posssible with DMC, is it? But it is not difficult to do without charge.
                  Oooops, I see DMC has both the decoder and the encoder. My information is out of date. Sorry!
                  • kimmchii
                    • Mar 2005
                    • 22
                    read and write are possible.
                      That's right, you can encode to real media audio format using dMC.
                      Real Networks of course have a program used for encoding specifically to .ra or .rm audio and video: Real Media Encoder (Helix encoder). The free version is not too bad either.
