Problem when converting .ogg to mp3
  • Semper
    • Feb 2005
    • 11
    Hi.
    I am converting .ogg to mp3 with the plugin, but when I do this the new .mp3 has some seconds of delay and have a bit of sound. I mean the 1st 2-3 seconds have a kind of the previous song fade out. Only after that comes the music of the track. So I have been cutting those previous seconds but this gives me a lot of work.
    Am I doing anything wrong and can those starting seconds be avoided?
    Thank you in advance.
    Semper
    Re: Problem when converting .ogg to mp3
    What plugin are you referring to?
    And what are the specs of your .ogg files and the .mp3 files?
    • Semper
      • Feb 2005
      • 11
      Thanks for your reply ChristinaS.
      I am using the codec: dBpowerAMP-OggVorbis-CLI (cause I have a Pentium 4) and the specs are +/- 80 kbps .ogg into 256 kbps .mp3.
      Semper
      • Semper
        • Feb 2005
        • 11
        Ooops I just made a boo-boo. That codec I am using but for the .mp3 I am using Lame.
        Thanks once again.
        Semper
          I'm assuming the ogg files themselves do not do this?
          • Semper
            • Feb 2005
            • 11
            You are assuming right. The .ogg files are fine - they start with its music track immediately.
            This is weird, seems like it is "grabbing" part of the former track or something. I am careful. I am not playing anyother song on the computer while I am encoding the .ogg into .mp3.
            Semper
              Try converting the ogg files to another format, such as wav, and see if this still happens.
              • Semper
                • Feb 2005
                • 11
                Ok I will. And I will post the results.
                Semper
                • Semper
                  • Feb 2005
                  • 11
                  Hi again.
                  I already encoded the same set of .ogg files into .mp3 and .wave and it still gives me the delay in .mp3 but not in the .wave files.
                  I also noticed that when I encode into .mp3 it shows me "7x Realtime Encoding" and into .wav it shows me "32x Realtime Encoding".
                  Is this realted in anyway? What can I do then?
                  Semper
                    Originally posted by Semper
                    Hi again.
                    The encoding difference is normal. Its because mp3 is a compressed format, wav is compressed. To go from ogg to mp3, it has to uncompress the ogg file, then recompress it into a mp3 file.
                    Are you changing the frequency or bitrate when you make the file mp3?
                    Also, try converting that wav file to mp3. Does it still have a pause?
                    • Semper
                      • Feb 2005
                      • 11
                      I dunno what you mean exactly but I am converting from +/- 80 kbps in .ogg into 256 kbps .mp3. No I don't change the frequency.
                      I did convert that .wav into .mp3 and it didn't give me the initial pause.
                      Semper
                      • Semper
                        • Feb 2005
                        • 11
                        I just tried LamedropXPd to convert from .ogg to .mp3 and the resulting .mp3 doesn't have have initial "gap".
                        Could it be the Lame.dll version? I di prefer dBpowerAMP.
                        Semper
                          What version of dMC are you using?
                          Also, are you applying any DSP effects when you are converting to mp3?
                          • adaywayne
                            • Nov 2004
                            • 383
                            Semper
                            I know this doesn't solve your problem, but do you have a particular reason for converting from OGG at 80Kbps to a so much higher bitrate in mp3? What happens if you convert the files to mp3 at 128Kbps....still the same problem?
                            • Semper
                              • Feb 2005
                              • 11
                              Hi again.
                              I am using Music Convertor from dMC v10.1
                              and Lame Version 3.93.1.
                              No, I am not using DSP effects.
