Lame DLL Max Bit Rate Problem
  • Ripper
    • Dec 2004
    • 11
    I moved the slider for max bit rate to 320, now I can't move it back to lower it. It's stuck at the extreme right.
    Re: Lame DLL Max Bit Rate Problem
    Check your advanced options, maybe something there blocks it.
    • adaywayne
      • Nov 2004
      • 383
      Yes. I had same problem. Go to Advanced and select "Alt. Preset ABR". That should solve it.
      • Ripper
        • Dec 2004
        • 11
        Those options still don't give me the ability to adjust the Max Bit Rate myself. They set it to fixed values. Thanks for your help though.
        • adaywayne
          • Nov 2004
          • 383
          Right. I wasn't thinking too straight. If you use VBR, is appears that the max is always set to 320.....I certainly could never move it from that position. I "solved" the problem by using the alt preset feature. Sorry for confusion.
            You right-click on the bar to select the position of the upper bitrate slider.
            • Ripper
              • Dec 2004
              • 11
              Right! Thanks for the tip. I think you solved a problem for a few people!
              • adaywayne
                • Nov 2004
                • 383
                Thanks. I should have read the label!!
