converting flac. to wav. problems
  • thom black
    • Jan 2005
    I'm new at this, and I'm trying to complete my first succesful download. I'm running windows xp and have managed to download the show, and convert the first three tracks (files), after that the converter keeps shutting down after only converting 3% of a file. I've uninstalled and reinstalled the poweramp converter twice only to get the same results. Any help?
    tb
    Re: converting flac. to wav. problems
    tb
    So you are converting .flac files to .wav and it stops after doing only 3% of the conversion of a single .flac file. What is the error message?
    Can you give information to the specs of your .flac file (hover the mouse of it and note what it says).
    Try a test conversion using dMC (no write) and you will know if the file is ok or not for dMC to handle.
    What setting are you using for the resulting .wav file?
    I'm asuming in all this that you have the .flac decoding codec installed to the same folder as all of dBpowerAMP which ought to be c:\Program Files\Illustrate. Also that you installed everything while being signed in as administrator on your pc.
