Mouse over audio files doesn't bring up stats of audio file
  • neilthecellist
    • Dec 2004
    • 1288
    Re: Mouse over audio files doesn't bring up stats of audio file
    did that. not working
      Ho! :confused: :headbang: :nospeak:
      • neilthecellist
        • Dec 2004
        • 1288
        i know. isn't it wierd?? I LOVED the mouse-over feature of dMC...and now it's gone...
        • adaywayne
          • Nov 2004
          • 383
          [QUOTE=neilthecellist]I have FireFox... but FireFox doesn't have to do with dMC , does it? (I uninstalled it and it still doesn't work)
          No, the browser has nothing to do with dBPA when converting files or any other process (except downloading, of course). But the problem you have is connected with the Windows operating system. Did you try clicking in empty space before hovering over the file?
            Have you by chance installed any sort of fancy software to turn your mouse pointer into something cute? I can see how this would interfere.
            • neilthecellist
              • Dec 2004
              • 1288
              #21
              NO, christina. LOL
              adaywayne, i tried that already. that didn't work either.
                #22
                When you want to open a file, do you single-click on it to open it, or double-click? Because if you double-click, you may have to single-click the file first to select it before the pop-up appears.
                  #23
                  Which brings the other question. Did you define file opening to work with a single click, or a double click? I have it set as a double-click. That's in Windows Explorer > Tools > Folder Options > General , right at the bottom.
                  • neilthecellist
                    • Dec 2004
                    • 1288
                    #24
                    file opening for me = double click
                      #25
                      Try single-clicking the file to select it and then hovering over it?
                      • neilthecellist
                        • Dec 2004
                        • 1288
                        #26
                        tried. NOT working......what the hell is going on here? !!!! ^_^ sorry i'm just a little upset that it's not working anymore....
                        there's only one solution left....
                        reformat my whole hard drive .....AGAIN
                        • adaywayne
                          • Nov 2004
                          • 383
                          #27
                          If this happened recently there should be no need to reformat. Just go to an earlier restore point when the feature was working.
                            • 44055
                            #28
                            Once a 'patriotic usa flag' on the task tray was found to stop popups, do you get popups for other files (ie .bmp - should give the dimensions).
                            • neilthecellist
                              • Dec 2004
                              • 1288
                              #29
                              WHOA! Thanks. I went to an earlier Restore Point. POOF! Problem solved. Thanks guys!
