Problems with monkey's audio files
  • das[ITA]
    • Dec 2004
    I have
    CODEC decompression error for 'F:\Musica\Track02.ape'
    How can I solve this problem?
    Re: Problems with monkey's audio files
    Have you downloaded the Monkey's Audio Codec from Codec Central ?
    • drspy00
      • 104
      I had a similar problem to this before I went overseas when I was trying to convert my entire collection to .ape then to mp3. i'm not sure how I overcome the problem but I think I just tried again and it worked or I might have just not added the problem tracks to the CD.
      • neilthecellist
        • Dec 2004
        • 1288
        er.....it's been many days and the guy who posted this thread has not responded.......
        oh well.
        • das[ITA]
          • Dec 2004
          I'm here
          And I have the problem
          please help me to solve it
            Your trying to decode a Monkey's file, right? Can you play the .ape file in a media player? Did you try to test-convert the file? What is the bits (24 or 16) and frequenzy (44100Hz, 48000Hz, etc.) of the file?
            • neilthecellist
              • Dec 2004
              • 1288
              Dude, you gotta tell us if you downloaded the Monkey's Audio codec or not..... That way we know if you're doing something or not...
              • das[ITA]
                • Dec 2004
                When I try to test convert the file, it says
                CODEC decompression error for 'F:MusicaTrack02.ape'
                I converted other Monkey's files and I had no problem
                How can I know the bits and frequency of the file?
                (thank you LtData)
                  Right-click on the file and click Properties, then click the "ID Tag" tab. Does it tell you the bits and frequency of the file?
                  If you don't see the "ID Tag" tab, open up your dMC Configuration (Start --> Programs --> dbPowerAmp Music Converter --> Configuration --> dMC Configuration) and click the "Explorer ID Tag Property Pages" checkbox and click OK. Now go back to the properties of the file and click the "ID Tag" tab.
                  • neilthecellist
                    • Dec 2004
                    • 1288
                    ....or you can simply hover your mouse over the ape file for 1-2 seconds and the stats should pop up.
                      Install the latest dBpowerAMP Monkeys Codec.
                      • neilthecellist
                        • Dec 2004
                        • 1288
                        speaking of which, what version of Monkey's do you have?
                        • brandonjp
                          • Mar 2003
                          • 53
                          i just started having this problem tonight...
                          I use dMC several several times everyday and have never had this problem until today. The APE file I was converting today was rather large [250mb] but even so, I've converted larger before without problems. I'm running everything up to date, but no luck. I'm still trying, so let me know if anyone has ideas
                          --bp
                          [left][font=Lucida Sans Unicode][b][color=black]brandon.pfeiffer | [/color][/b][url="http://www.brandonjp.com/"][color=black]brandonjp.com[/color][/url][/font][/left]
                          [left][url="http://www.littleamericarecords.com/"][font=Lucida Sans Unicode][color=black]littleamericarecords.com[/color][/font][/url][font=Lucida Sans Unicode][color=black] [b]|[/b] [/color][/font][url="http://www.cuestreetstudios.com/"][font=Lucida Sans Unicode][color=black]cuestreetstudios.com[/color][/font][/url][/left]
                            --bp
                            What was the error?
                            How many channels did the Ape file have that you were converting?
                            What were you converting to?
                            Source and destination frequency?
                            • brandonjp
                              • Mar 2003
                              • 53
                              converting from an 118 minute long, 16-bit, 2-channel, 44.1-kHz ape file made with monkey's audio version 3.97 @ Extra High compression
                              converting to 16-bit, 2-channel, 44.1-kHz wav
                              it usually takes around 2 min 10 sec to get 38% completed then gives this error:
                              "CODEC decompression error for 'D:\0-TRADES\BURN_AUDIO\lar at the pc.ape'"
