Power Pack not registered
  • akirainblack
    • Dec 2004
    I've just installed the latest version of DBPoweramp and then re-installed my registered power pack.
    However it still says it's unregistered!!
    ??? What's going on??
    Have I done something in the wrong order or something??
  • Razgo
    • 2532
    Re: Power Pack not registered
    well it should be fine : http://forum.dbpoweramp.com/showthread.php?t=6432
    but there shouldn't been a need to reinstall the registered powerpack, just install the latest dmc over the top, but it will uninstall during the process.
    there is another method in place that would bring you up to date also by going here and entering your details : http://www.dbpoweramp.com/registration/
    • akirainblack
      • Dec 2004
      Still says Unregistered on the power pack button
      Spoon sent me a link to the registered download as I can't find the original email I got.
      • akirainblack
        • Dec 2004
        Can no-one explain this at all??
          Uninstall dBpowerAMP Music Converter, then install the Registered version (from link supplied), make sure you are logged onto the computer as Administrator so that the install is sucessfull.
