Aux input Problems
  • chrsshif
    • Dec 2004
    Aux input Problems
    I Am running a windows xp machine and can not run the aux input. When I try to use the aux input to record a MP3 it gives me the Error "CODEC required to encode file temp1.mp3 can not be opened". The codec works fine when I use the other sections of the converter. I have tried uninstalling and reinstalling, And upgrading to version 11 and still have the same error in the aux input. My system is an AMD 3000+ W/ 1GB OR RAM, A SOUND BLASTER AUDIGY 2 ZS sound card, and A Nvidia geforce FX5700le vid card, running Windows XP Home SP2. Please help. :cry:
  • Wayne
    • Aug 2002
    • 1254
    Re: Aux input Problems
    Have you tried recording to any other formats, for example wav?
    Wayne
      • 46167
      Try different mp3 compression settings.
      • chrsshif
        • Dec 2004
        I have tried .wav and it worked in wave. I have also tryed adusted my settings for the .mp3 and under .mp3 I still get the unable to open codec error on MP3 format.
        • Wayne
          • Aug 2002
          • 1254
          When you recorded to wav what format did it produce? Was it 24bit?
          Could you convert the created wav to MP3?
          Wayne
          • chrsshif
            • Dec 2004
            Yes Wav files recorded did convert sepretly to the mp3 format. I like not haveing to do the second step if I can get the software to work properly.
            • Wayne
              • Aug 2002
              • 1254
              What settings are you trying to use to create your MP3 files.
              Wayne
              • chrsshif
                • Dec 2004
                Included LAME Codec, 192kbps, Stereo, and 44100 or 48000 Sample rate. These are the same settings I use when converting exiting files or CD's. Which work Beautifly on all but the aux input.
