Need help on converting wav to mp3
  • SoulTrain
    • Nov 2004
    • 14
    hey guys when i try to convert a wav file into an mp3 i get this messege.
    The CODEC required to compress 'C:\Program Files\Downloads\11.mp3' could not be opened.
    any idea why and how to fix it so i can convert it thanx.
  • Razgo
    • 2532
    Re: Need help on converting wav to mp3
    is it a 24bit wav or 16bit? you have the latest dmc installed? http://www.dbpoweramp.com/dmc.htm
    • SoulTrain
      • Nov 2004
      • 14
      i have the new version installed and the wav is a 16-bit wav.
      • Razgo
        • 2532
        try: start-->programs->dbpoweramp music converter-->configuration-->dmc configuration
        and look to see if you can see lame mp3 codec in the list as intalled.
        and does the powerpack show registered?
        • SoulTrain
          • Nov 2004
          • 14
          no its not installed.
          • Razgo
            • 2532
            ok i should have just asked then how long have you had dmc installed for? the latest version should have got you 30 days trial for the mp3 codec. refer here: http://forum.dbpoweramp.com/showthre...9099#post29099
            did it say in that window that powerpack unregistered or trial version? did you purchase a copy of dmc at some stage?
            • SoulTrain
              • Nov 2004
              • 14
              i just downloaded the prog earleir.
                If the encoder trial is up, then that is the error message given.
                Try different bitrates or frequencies on the mp3 compression page.
                • Razgo
                  • 2532
                  ok, we still need to know what it says in : start-->programs->dbpoweramp music converter-->configuration-->dmc configuration
                  as in does it say powerpack unregistered? or trial version?
                  • SoulTrain
                    • Nov 2004
                    • 14
                    it says registered no 30 trial days remaining
                    • Razgo
                      • 2532
                      Spoon, i am wondering if it is possible to program dmc so it doesn't show the mp3 convert to option anymore after the trial has expired? as it looks like this error messsage is going to appear on the forums a lot. at least then when someone says their mp3 codec convert to option dissapeared we know what happened. just a thought.
                      • Razgo
                        • 2532
                        hmmmm... well that's not what it should be saying if thats a direct quote from what you see.
                        you may need to uninstall and re install to see if that clears up things.
                        • SoulTrain
                          • Nov 2004
                          • 14
                          So do i need to download and instal the lame mp3 encoder thing or what.
                            Actually Razgo, that's exactly what mine says too. And you should be able to encode to mp3 just fine. Have you tried other bitrate and frequencies?
                            • SoulTrain
                              • Nov 2004
                              • 14
                              here i screen caped it for you lol.
                              is that what you meant.
