Encounters Problem and Closes
    Am tyring to run the music coverter on a new XP computer...a couple second into the conversion it stops and says "MusicConverter.exe has encountered a problem and needs to close..." etc. Any ideas how to fix this?
    Re: Encounters Problem and Closes
    Ok...got it to convert to Mp3 first converting to wav and then to mp3...but now none of the players will open the file? Any ideas?
      convert what to mp3 and wave?
        hes spoon...you and I are communicating on two threads....when i try and covert an m4a converted with hymn to an mp3 on dbpower the program encounters a problem and shuts down...I have to first convert the m4a to wav then to mp3..which then wont play anywhere
          Try playing the wav file, try playing the m4a file.
            nothing will pay the coverted m4a, wav or mp3 files....the original file is an mp4 which plays fine on my itune player. This conversion process does not appear to be working
              It is the hymm protection stripper that is not working.
