RA Codec problem(?) Question..
  • savagcl
    • Aug 2004
    • 439
    Converting some RA and RM files.
    1. Problem: RA or RM to WAV, sound seems to "step on itself" or over-lapped.
    2. Problem: RA or RM to mp3, same problem as 1 above.
    3. Using the AUX-Converter, works good to either wav or mp3.
    Is the RA/RM Codec in testing or has it been finalized?
    savagcl
    Re: RA Codec problem(?) Question..
    savagcl
    When you play the .ra or .rm files in real Player, what information do you get about them in View > Clip Properties > Clip Source ?
    • savagcl
      • Aug 2004
      • 439
      Can't tell you, Christina.
      I dont have realplayer i have real-alternative and it beats real player by a mile.
      I have winamp setup to run ra and rm files, works great.
      but, since you ask for info - here is what is reported by winamp -
      File: Statue of a Fool.rm
      Filesize: 481350 Bytes
      Title:
      Author:
      Comments: RealEncoder 5.1.0.32 Win95 4.10 2222 Pentium MMX 1 Live = 0 ac=
      20 Kbps Music Stereo abw = 20.0 asi= 44100 abi = 16 abo= 16 ach = 2
      Statistics:
      Maximum Bit Rate: 20104
      Average Bit Rate: 20104
      Maximum Packet Size 480
      Number of packets: 968
      Duration: 185433 ms
      Number of streams: 1
      Hope the above helps....
      clif
        Title:
        Author:
        Statistics:
        Duration: 185433 ms
        clif
        Don't know if that's a potential problem, but it may be advisable to actually have real player as well in order for dMC to convert real media files. Perhaps this is what's causing some problems for you.
        However i'm not sure about the version of RealEncoder used - Win95???
        I wonder if it is in fact supported by dMC's real media codec.
        Anyway, here's what it says at Codec central:
        Requires RealAudio v8 Installed [rp8-setup.exe, or from OldVersion]
        I have been informed that Real Alternative 1.11 can be used instead of RealAudio v8.
        When Converting the % bar will remain at 0%, the computer will 100% and conversion will take exactly the length of the audio file
          Yes, i saw that "win95" thing. So i guess they are pretty old files to start with.
          I just use the AUXillary converted instead, works fine that way. It just limits me
          to doing 1 at a time. No biggie there. The batch file conversion was a bonus and
          would have been useful but i can live without it for RA/RM files.
          Thanks, Christina,
          clif
          • bilbofrodo89
            • Oct 2004
            does anyone know if there is a new version of the Real Audio codec out that fixes some of the bugs of the previous version? such as making it convert to mp3 faster, or making the progress bar advance past 0%? thanks
            • Mosi
              • Feb 2005
              I have question.
              I want to convert Ra files to MP3.
              I have the dbpoweramp and the encoder but when i start to press convert
              he is still by 0 % after 10 minutes
              Can you help me
                • 46228
                It will convert at x1 speed, you could also try the directshow decoder (in the beta section) and install real alternative codecs also.
