m4a to aac: more than 1 track doesn't work
    when I try to convert m4a to aac, I can only encode one track at a time correctly. If I select 2 or more tracks, each track will be split into one aac file which is about half the size of the m4a und a second ".m4a.t1" file.
    If I just shoose one file at a time it works just fine. I have installed
    music converter r10,
    aac codec,
    aac and mp4 decode codec,
    aac to mp4 codec.
    (on XP SP2)
    Does anybody know how to solve this?
    PS: Apart from that, the music converter is just awesome...
    Re: m4a to aac: more than 1 track doesn't work
    The Psytel AAC codec requires the aac.enc file be downloaded and installed on top of the AAC codec. Have you done this?
    Spoon recommends the FAAC codec. YOu might try this as an alternative.
    Bill Mikkelsen
