I need help!!
  • Scteker
    • Aug 2004
    I need help!!
    [COLOR=Black]WHEN I GO INTO MY MUSIC FOLDER AND SCROLL OVER MY MUSIC IT SAYS: GETPOPUPINFO.EXE. WHAT SHOULD I DO, OR WHERE DO I GET THIS EXTENSION??? [/COLOR]
    Re: I need help!!
    Does the message say anything else about getpopupinfo.exe?
    This is a routine built in to dBpowerAMP Music Converter (dMC) to show information about an audio file when you scroll over it. This can be turned on or off through dMC Configuration (go Start>All Programs>dBpowerAMP Music Converter>Configuration>dMC Configuration. To activate it check the box that says "Popup Info Tips in Explorer". To deactivate it, remove the check from the box. I believe that your message may have a bit more to say. In that case turning off the feature should prevent your message from showing up but you won't get the advantage of being able to access track info when your mouse goes over the file.
    If that is the case, please tell us what version of Wondows you are using and the full text of the message you are getting.
    Bill Mikkelsen
    • Scteker
      • Aug 2004
      Re: I need help!!
      Thanks, I greatly appreciate your help!!!!!!!!
      P.S.
      [SIZE=7]I LOVE NC[/SIZE] :komisch9:
