Help! Cannot use Monkeys Audio codec
  • Ffabbia
    • Jul 2004
    Hi there.
    I've been attempting to convert a 32 bit wav file to Ape format using the Monkeys Audio Codec.
    Upon attempting to do so, I get the following message :
    The CODEC required to decompress <filename.wav> could not be opened.
    ACM Codec Not Installed 'IEEE Float'
    I am unable to locate any reference to this 'ACM' codec on the DBPowerAMP website, or Codec central.
    This 'ACM' codec is mentioned on several (other) web sites, and apparently available for download, however the download never appears to contain any obvious setup files, and instead appears to consist of an .inf file. I am uncertain as to how to procede.
    I have uninstalled Music Converter, and all associated codecs, and re-installed the latest version, however this has not resolved the problem.
    I have also attempted to download and install the actual Monkeys Audio software from their home page, (just on the off chance). No joy...and the conversion programme supplied with this software does not work either.
    I am likely overlooking something really obvious here, but I would be greatful for any assistance in this matter.
    Thank you.
    • 46228
    Re: Help! Cannot use Monkeys Audio codec
    What created the wave file? can you send me a small example of such wave file (less than 6MB) to :
    • Ffabbia
      • Jul 2004
      Thanks very much. The wav is a mixdown created using CoolEdit Pro 2.
      I'll send you a snippet as you suggested as soon as I am able.
      • Imcuneo
        • Nov 2005
        We are having the same problem with wav mix downs from audition (created from Cool Edit). And I'm only (trying to) make mp3's (lame).
          • 46228
          R11.5 is able to read IEEE float files.
          • melonsagrado
            • Dec 2005
            i´ve the same problem with a file made with de Dinesys 3, when i´m convertin to Mp3 this messenges appear:
            The CODEC required to decompress 'C:\nuño\X4\wavs del dinesys\L0005.WAV' could not be opened.
            wich is the codec to convert Dinesys wav files to Mp3? where can ia download it?
              Re: R11.5 is able to read IEEE float files.
              Did you install dMc r11.5?
              • gameplaya15143
                • Sep 2005
                • 276
                why not just export the wav in 24bit or 16bit?
                (topic should be 'cant open 32bit floating point pcm/wav files')
