Problem with Lame conversion using VBR
  • PaulS
    • Jun 2004
    I am having a problem with the Lame MP3 conversion plug-in (the one that comes as part of the standard install).
    If I select "Advanced" and then "no preset" as the quality I can select VBR. If I then go back to the front screen I see two sliders for the quality. I can move the lower one up and down from 32-320 but the upper one will only move upwards. Once you have moved it fully to the right it is stuck there.
    Am I doing something wrong or is this a bug?
    Thanks.,
    Paul
    ps. this is a great product. I've tried several over the last few weeks and this one beats the rest hands down.
    • 46139
    Re: Problem with Lame conversion using VBR
    Use the right mouse button.
