Wont rip?? Help!
  • boner
    Wont rip?? Help!
    Hi All,
    Todays my first day of using dbpowerAMP. I tried ripping a cd, but it wouldnt work. It gave me this message:
    CODEC decompression error for '\\CdRom\Track01.cda'
    Unable to Rip track - make sure correct Ripping method is selected and CD Drive supports digital audio extraction.
    I tried ripping some other cds, and that worked fine. Its just this particular cd thats giving me problems. Am i doing something wrong here?
  • ferris209
    • Oct 2003
    • 181
    Re: Wont rip?? Help!
    I've never had that before, may be that CD has some kind of security on it. It sounds to me to be more CD problem than a program problem though.
    Brandon
    "It's better to have it and not need it than to need it and not have it!" - John Wayne
    [URL=http://www.powersnipe.com?upartner=21095]Powersnipe is the best for Ebay![/URL]
    • ferris209
      • Oct 2003
      • 181
      Check this search of old threads
      also what version of Windows are you using?
        hey ferris,
        thanks for the reply. im using winxp. yeah, i figured out it was some sort of copyright protection. i tried using the "marker method," and also tried holding the left shift button down before/during/after putting in the cd. didnt work. i finally got this cd to rip using cd manipulator, which took about 6 hours. now im left with a .wav file thats over 2.5 gigs. what the hell? anyways, any help is appreciated. by the way, that link doesnt work :(
        • ferris209
          • Oct 2003
          • 181
          Cool, now you ought to be bale to use the Dbpoweramp Converter and make those wave files into mp3's. Youu should have yourself some tunes playing with no prob!
          • ferris209
            • Oct 2003
            • 181
            Sorry about that link, just go up to search and search the threads for "CODEC decompression error", thats pulls every thread about that problem anybody as had for the past ocuple of years.
