dMC using Nero built-in mp3PRO encoder
  • gYsmO
    Is it possible? Can you create a plug-in for dMC that uses the Nero built-in encoder to convert files to the mp3PRO format? THOMSON mp3PRO encoder only supports 64kbps encoding and i haven't found anywhere the full version.
    Re: dMC using Nero built-in mp3PRO encoder
    I tried the nero mp3pro, but it just crashed, perhaps there is something special about it...didn't have time to look into it :(
    • gYsmO
      ok... i guess. but is there any other way i can convert mp3PRO files at bitrates higher than 64kbps?
        It is the only codec I know of.
