VBR (Lame) - track length problems in iTunes for Win
    Any ideas on getting iTunes to recognize the proper track length for VBR Lame files?
    Or is there something I can do to dbpowerAMP Converter to make iTunes happy?
    thanks much
    -rob
  • Wayne
    • Aug 2002
    • 1254
    Re: VBR (Lame) - track length problems in iTunes for Win
    What version tag ids are you using? I think that there is a problem with vbr and version 2 tags.
    Wayne
      Sorry - I'm not sure. I'm ripping with dBpowerAmp... how do I check the tag version?
      thx for your help
      -r
      Wayne
      • Wayne
        • Aug 2002
        • 1254
        Run the dMC Configuration program. One of the options enables you to select what version tags to be created.
        Wayne
