audio cassette to mp3 using aux input
  • mailman
    • 14
    Using Aux. Input I have connected my audio cassette player from the headphone jack to the mic on my pc (PIII 650). The volume is still showing low even with the red on full and the mic volume at max. The mp3 I create plays and all that is heard is a low buzzing sound. Any tips? Thanks!
  • Wayne
    • Aug 2002
    • 1254
    Re: audio cassette to mp3 using aux input
    Does your PC have a line-in as well as the mic? I had this problem when I incorrectly used the microphone input. Using the line-in should result in clearer sound.
    Wayne
    • mailman
      • 14
      Yes, thanks. I tried this and the volume comes way up, but the mp3 is now a louder buzzing sound. Any thoughts...
      • ferris209
        • Oct 2003
        • 181
        What kind of buzzing? Steady and constant or just recurring when the music gets loud? If it is steady and recurring you may ought to check your wires and make sure there ain't a small short in it anywhere. Buzzing on the loud parts of the songs could be attributed to too much volume going into the computer from the cassette player. You may have to work with all the volume controls on the device and your computer to get it just right though.
        Brandon
        "It's better to have it and not need it than to need it and not have it!" - John Wayne
        [URL=http://www.powersnipe.com?upartner=21095]Powersnipe is the best for Ebay![/URL]
        • ferris209
          • Oct 2003
          • 181
          Also if you have any flourescent lights in the room with your computer that could cause interference. Other things could cause interference also, large backup battery packs, stuff like that.
          • Wayne
            • Aug 2002
            • 1254
            Another cause for buzzing is where the PC and Cassette player are not earthed properly (or to the same level). How is the cassette player powered? Mains or battery?
            Wayne
            • mailman
              • 14
              OK, I have now changed my wires and tried another player. The 1st was battery powered and the 2nd is plugged to a power outlet. The result is the same. The mp3 playback noise is perhaps more like a fuzzy background sound with an intermitent beep. Any other possible fixes?
              • mailman
                • 14
                Problem Solved!! Both cables I was using were bad. A new cable did the trick. Thanks to everyone for there input!!!
                • ferris209
                  • Oct 2003
                  • 181
                  Great! No Problem, bad wires seem to be the culprit in 92.5% of my problems.
