Need help with everything
  • chefdug
    I purchased some songs from www.walmart.com. They are wma which are coded. I need to burn them to a cd. I tried with the cd rip program from here and nothing. Kept getting error, in booth ripping and converting. Can some one tell me what I neede (ripper, codec, converter,...) I must be dumb or doing something wrong.
    :vmad: :cry: :vmad: :cry: :vmad: :cry:
  • Wayne
    • Aug 2002
    • 1254
    Re: Need help with everything
    Posted response to your other post here http://forum.dbpoweramp.com/showthread.php?t=4572
    You could try searching the forum for previous postings.
    Wayne
    • JahSun
      • Nov 2003
      • 69
      What happens when you try to burn them with nero? If you select Audio CD, and drag the naughty WMA files over, you should be able to burn them. You can even remove the copy protection under the properties for each song.
      Isn't it crappy that the music industry (record companies & retailers) try and charge you an equivalent amount for downloading a song as for buying the same song on CD? It costs them nothing to let you download it. There is no shipping or storage. & the friggin song quality is usually a crappy 128k. Then to add insult to injury, they copy protect your song in a way that severely limits your ability to use your property. When you buy a cd, you can take the same cd and play it in your car, loan it to your buddy so he can get hip to it, and you even get liner notes and a cardboard fascimile of the album cover to hang on your wall.
      Oh well, sorry for the rant...
