Installation problem
  • Mike Lance
    • Nov 2023
    Running windows 10 on laptop
    Purchased dbpoweramp Converter/ripper for my own use.
    Saved .exe file
    Double click it ... blank box with the the spinning circle image appears and spins ... nothing else happens.
    Any suggestions please?
    THanks
    Mike
    • 6188
    Re: Installation problem
    first i might try to redownload the install file. You can also try to run exe file by right clicking and selecting "run as administrator"
    • Mike Lance
      • Nov 2023
      Thanks for your reply ... I already did suggestion 1 ....... just tried *2 ....... both same result ...... no change. Thanks for trying though.
        • 1914
        Do you have a security software running? Which one?
        • Mike Lance
          • Nov 2023
          Nothing special .. just Windows Defender
          • Mike Lance
            • Nov 2023
            I have now Uninstalled the trial version ... no change, problem still there.
            Now I'll restart my laptop to see if that has any effect.
            • Mike Lance
              • Nov 2023
              It worked .. installation completed.
              THREAD CAN CLOSE (DO i HAVE TO DO THAT?)
