Conversion of special characters in Arange Audio
  • Al1967
    • Jun 2019
    Good morning/afternoon/etc.,
    I have a question that I haven't been able to find an answer for yet.
    Is there any way to adjust what Arange Audio converts special characters to that artists use in their naming structure? For example: it will convert a : to a ; while I'd like it to convert it to a -. Or it will convert * / | \ all to a -.
    I am using the latest version of Music Converter on Windows 10.
    Or is this a µsoft thing?
    Thank you for any & all suggestions,
    Al.
    G2J!
    • 46228
    Re: Conversion of special characters in Arange Audio
    In dBpoweramp Control Centre on the advanced options page is the filename character replacement, here you can control which values are used.
    • Al1967
      • Jun 2019
      Thank you Spoon for you quick & accurate reply.
      I found it & made the adjustments that I prefer. I didn't realise that "Filename Restricted Characters" was what I was looking for.
      Thank you again,
      Al.
      G2J!
      • Al1967
        • Jun 2019
        It doesn't work. Even after I adjusted them, & even rebooted, it still uses the default replacements!
        I have confirmed that the latest version (2023-10-10 [64-bit]) is being used.
        Attached is a print screen:
        Thank you,
        Al.
        G2J!
          • 46228
          Using R6 of arrange audio?
          • Al1967
            • Jun 2019
            I just reinstalled R6 & now it works!
            I guess I've got to remember to reinstall &/or update Codecs after updated main program!
            Thank you Spoon,
            Al.
            G2J!
