DSP effect "Bit Depth" causes loud distorted audio when converting 32bit float
  • DCWH
    • Feb 2022
    System: Windows 10
    Version: 17.6 64bit
    When converting certain 32bit float .wav file, DSP effect "Bit Depth" causes distorted audio, in all encoding format (.flac, .mp3 etc.)
Name:	dsp bit depth.png
    Using format option has no problem
Name:	format option.png
    The problematic .wav is generated by Bitwig Studio
    encoder setting shows IEEE float
    but sample size is 32bit
    Perhaps the DSP effect is unable to identify the 32bit file as float
    Link for the generated audio files:
    bitwig export.wav
    32bit float .wav generated by Bitwig
    bitwig export DB DSP 16bit.wav
    DBpoweramp conversion using DSP effect, causes distorted audio(LOUD WARNING)
    bitwig export DB format 16bit.wav
    DBpoweramp conversion using format option, has no problem
    FL export.wav
    32bit float .wav generated by FL Studio
    FL export DB DSP 16bit
    DBpoweramp conversion using DSP effect, has no problem
    • 46228
    Re: DSP effect "Bit Depth" causes loud distorted audio when converting 32bit float
    Looks like a bug, will fix, for next update
