Need help setting ID tags after converting wavs
  • gr8fox
    • Jan 2022
    Hi all, I know someone has a way to do this so I don't have to reinvent the wheel:
    I have a lot of ripped vinyl in folders like this:
    E:\Vinyl rips\The Jets - Private Number (12 inch)\Audio Files\The Jets - 01 - Private Number (12 inch mix).wav
    I need to easily convert these wavs to FLAC (I guess I can't drag and drop to file converter?)
    I'd like them converted to the folder E:\FLAC.
    And then somehow infer the information from the folder and filenames so I get these tags:
    Artist, album, track number and song name.
    Then I can more easily put them into MusicBee without going through 8 billion steps. Otherwise I have to use MusicBee to infer tags, and I can't get that program to do what I want either.
    Does anyone have a good way to do this with dbpoweramp?
    Thanks much!
    Re: Need help setting ID tags after converting wavs
    There is Tag From Filename utility codec:
    and help on using batch converter to convert:
