Tagging Problem
    Tagging Problem
    I am having a minor problem with ripping Compilation CD's. If I rip it with iTunes the software correctly puts the different artists in the artist section of the tag. However whenever I do a compliation cd with dbpoweramp it usually just have various artist as the artist name and in the song field of the tag is has artist name\song name. Is there anyway to get the program to correctly fill in the artist name so I dont have to go back and do it?
    • 46167
    Re: Tagging Problem
    That is one of the features of the 'Power Pack', install and see.
    • horvath
      • Mar 2004
      Re: Tagging Problem
      I installed PowerPack, but I can't see HOW to edit the ID tags -- HELP!
      What do I do???
      Aren't there any help files or tutorials to be had?
      Alan
      AlanHorvath.com
      • Wayne
        • Aug 2002
        • 1254
        Re: Tagging Problem
        Click on the compilation button, which should now appear in the Audio CD Input window, before you rip the tracks.
          Re: Tagging Problem
          Thanks ... I finally figured out all I had to do was right-click on a file and I can then access and change the ID tags -- got the info from another thread here.
          Alan
