Conversion issues after using PerfectTunes ID Tags
  • Cyrille81
    • Nov 2021
    Hello,
    If I'm editing Tags of files and after that I convert them with Music Converter I have lot of error messages at the end. For exemple here I'm trying to convert FLAC files into Apple Lossless and these are the error messages I have at the end:
    Code:
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/01 Two Of Us (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.01 The Beatles - Two Of Us (2021 Mix).m4a'
       indicated sample count does not match decoded sample count, possible file corruption
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/03 Across The Universe (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.03 The Beatles - Across The Universe (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/04 I Me Mine (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.04 The Beatles - I Me Mine (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/05 Dig It (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.05 The Beatles - Dig It (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/06 Let It Be (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.06 The Beatles - Let It Be (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/07 Maggie Mae (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.07 The Beatles - Maggie Mae (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/08 I've Got A Feeling (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.08 The Beatles - I've Got A Feeling (2021 Mix).m4a'
       Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/Disc 1/08 I've Got A Feeling (2021 Mix).flac'
       Unable to tag file '/Volumes/music/A trier/Disc 1/1.08 The Beatles - I've Got A Feeling (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/09 One After 909 (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.09 The Beatles - One After 909 (2021 Mix).m4a'
       Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/Disc 1/09 One After 909 (2021 Mix).flac'
       Unable to tag file '/Volumes/music/A trier/Disc 1/1.09 The Beatles - One After 909 (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/10 The Long And Winding Road (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.10 The Beatles - The Long And Winding Road (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/11 For You Blue (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.11 The Beatles - For You Blue (2021 Mix).m4a'
       Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/Disc 1/11 For You Blue (2021 Mix).flac'
       Unable to tag file '/Volumes/music/A trier/Disc 1/1.11 The Beatles - For You Blue (2021 Mix).m4a'
    Error converting to Apple Lossless, '/Volumes/music/A trier/Disc 1/12 Get Back (2021 Mix).flac' to '/Volumes/music/A trier/Disc 1/1.12 The Beatles - Get Back (2021 Mix).m4a'
       Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/Disc 1/12 Get Back (2021 Mix).flac'
       Unable to tag file '/Volumes/music/A trier/Disc 1/1.12 The Beatles - Get Back (2021 Mix).m4a'
    And if I'm trying to convert the FLAC files into Apple Lossless without editing the tags of the FLAC files with ID Tags, I have no issue at the end of the conversion. So I suppose ID Tags modifies something in the files that Music Convert doesn't like but don't know what.
    I have the latest version of dBpoweramp and PerfectTUNES on macOS Monterey 12.0.1.
    Re: Conversion issues after using PerfectTunes ID Tags
    What created those FLAC files? normally FLAC files have inbuilt md5 checksums, however yours do not, so there is no certain way to know if the FLAC files are corrupted.
    Within the flac file is a header which says how many samples (length) the track is, when dBpoweramp has decoded the track, the length is less than reported in the header, it is likely those files are corrupted.
    This on is for certain a corrupted flac file, the header is missing.
    • Cyrille81
      • Nov 2021
      I haven't created the FLAC of my first post so I retried with a CD I just ripped to be sure.
      So I ripped the CD with CD ripper and this is the log file generated:
      Code:
      dBpoweramp Release 17.5 Digital Audio Extraction Log from 2021-11-17 16:32:31
      OS version: Version 12.0.1 (Build 21A559)
      Drive & Settings
      Ripping with drive 'disk6   [PIONEER - BD-RW   BDR-206]',  Drive offset: 667,  Overread Lead-in/out: No
      AccurateRip: Active,  Using C2: No,  Cache: 1024 KB,  FUA Cache Invalidate: No
      Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: Max
      Ultra::  Vary Drive Speed: No,  Min Passes: 3,  Max Passes: 6,  Finish After Clean Passes: 2
      Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 34
      Encoder: FLAC -compression-level-5
      Extraction Log
      Track 1:  Ripped LBA 0 to 17214 (3:49) in 1:17. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.01 Nolwenn Leroy - Loin.flac
        Secure  [Pass 1 & 2, Ultra 1 to 3]
        CRC32: BC1731BD     AccurateRip CRC: 4B5BBC12 (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-1]
      Track 2:  Ripped LBA 17214 to 34562 (3:51) in 1:01. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.02 Nolwenn Leroy - Occident.flac
        CRC32: 7BB51473     AccurateRip CRC: F164142F (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-2]
      Track 3:  Ripped LBA 34562 to 45310 (2:23) in 0:35. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.03 Nolwenn Leroy - Tu me plais.flac
        CRC32: DC0D8E81     AccurateRip CRC: D64418D7 (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-3]
      Track 4:  Ripped LBA 45310 to 62131 (3:44) in 0:52. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.04 Nolwenn Leroy - Le tournis.flac
        CRC32: 3249652D     AccurateRip CRC: 547A977A (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-4]
      Track 5:  Ripped LBA 62131 to 79526 (3:51) in 0:50. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.05 Nolwenn Leroy - La houle.flac
        CRC32: 8DE2D24A     AccurateRip CRC: C4564DE7 (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-5]
      Track 6:  Ripped LBA 79526 to 98473 (4:12) in 0:52. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.06 Nolwenn Leroy - Mon beau corsaire.flac
        CRC32: DE60C39F     AccurateRip CRC: 2981040C (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-6]
      Track 7:  Ripped LBA 98473 to 115367 (3:45) in 0:44. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.07 Nolwenn Leroy - Bresil, Finistere.flac
        CRC32: 306DAF21     AccurateRip CRC: 2B48556B (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-7]
      Track 8:  Ripped LBA 115367 to 131376 (3:33) in 0:40. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.08 Nolwenn Leroy - Abysses.flac
        CRC32: 5484E3C6     AccurateRip CRC: 8DE9B40B (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-8]
      Track 9:  Ripped LBA 131376 to 149732 (4:04) in 0:43. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.09 Nolwenn Leroy - La lune en plein jour.flac
        CRC32: 9CD8E0A4     AccurateRip CRC: CEB6797C (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-9]
      Track 10:  Ripped LBA 149732 to 167442 (3:56) in 0:40. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.10 Nolwenn Leroy - Changer l'eau des fleurs.flac
        CRC32: C1544154     AccurateRip CRC: 6AC6E6E7 (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-10]
      Track 11:  Ripped LBA 167442 to 183376 (3:32) in 0:35. Filename: /Volumes/music/A trier/Nolwenn Leroy/La cavale/1.11 Nolwenn Leroy - La cavale.flac
        CRC32: EBF7B236     AccurateRip CRC: D0ADCB74 (CRCv2)     [DiscID: 011-00108c5d-009010d3-7d098d0b-11]
      11 Tracks Ripped Securely
      After that I tried to convert these FLAC files into Apple Lossless with Music Converter and it was successful, no error message at the end.
      After that I edited some tags into ID Tags (changing the genre and added a comment) in the FLAC files and I tried to convert the FLAC with edited tags into Apple Lossless with Music Converter and again I have errors at the end:
      Code:
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.09 Nolwenn Leroy - La lune en plein jour.flac' to '/Volumes/music/A trier/La cavale/1.09 Nolwenn Leroy - La lune en plein jour.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.09 Nolwenn Leroy - La lune en plein jour.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.09 Nolwenn Leroy - La lune en plein jour.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.10 Nolwenn Leroy - Changer l'eau des fleurs.flac' to '/Volumes/music/A trier/La cavale/1.10 Nolwenn Leroy - Changer l'eau des fleurs.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.10 Nolwenn Leroy - Changer l'eau des fleurs.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.10 Nolwenn Leroy - Changer l'eau des fleurs.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.11 Nolwenn Leroy - La cavale.flac' to '/Volumes/music/A trier/La cavale/1.11 Nolwenn Leroy - La cavale.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.11 Nolwenn Leroy - La cavale.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.11 Nolwenn Leroy - La cavale.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.01 Nolwenn Leroy - Loin.flac' to '/Volumes/music/A trier/La cavale/1.01 Nolwenn Leroy - Loin.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.01 Nolwenn Leroy - Loin.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.01 Nolwenn Leroy - Loin.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.02 Nolwenn Leroy - Occident.flac' to '/Volumes/music/A trier/La cavale/1.02 Nolwenn Leroy - Occident.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.02 Nolwenn Leroy - Occident.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.02 Nolwenn Leroy - Occident.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.03 Nolwenn Leroy - Tu me plais.flac' to '/Volumes/music/A trier/La cavale/1.03 Nolwenn Leroy - Tu me plais.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.03 Nolwenn Leroy - Tu me plais.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.03 Nolwenn Leroy - Tu me plais.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.04 Nolwenn Leroy - Le tournis.flac' to '/Volumes/music/A trier/La cavale/1.04 Nolwenn Leroy - Le tournis.m4a'
         md5 did not match decoded data, file is corrupt.
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.05 Nolwenn Leroy - La houle.flac' to '/Volumes/music/A trier/La cavale/1.05 Nolwenn Leroy - La houle.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.05 Nolwenn Leroy - La houle.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.05 Nolwenn Leroy - La houle.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.06 Nolwenn Leroy - Mon beau corsaire.flac' to '/Volumes/music/A trier/La cavale/1.06 Nolwenn Leroy - Mon beau corsaire.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.06 Nolwenn Leroy - Mon beau corsaire.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.06 Nolwenn Leroy - Mon beau corsaire.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.07 Nolwenn Leroy - Bresil, Finistere.flac' to '/Volumes/music/A trier/La cavale/1.07 Nolwenn Leroy - Bresil, Finistere.m4a'
         Encountered 'FLAC__STREAM_DECODER_READ_METADATA' in FLAC File '/Volumes/music/A trier/La cavale/1.07 Nolwenn Leroy - Bresil, Finistere.flac'
         Unable to tag file '/Volumes/music/A trier/La cavale/1.07 Nolwenn Leroy - Bresil, Finistere.m4a'
      Error converting to Apple Lossless, '/Volumes/music/A trier/La cavale/1.08 Nolwenn Leroy - Abysses.flac' to '/Volumes/music/A trier/La cavale/1.08 Nolwenn Leroy - Abysses.m4a'
        Where ever you are writing to, the files are corrupted. The location is a network drive? or local drive?
        • Cyrille81
          • Nov 2021
          It is a network drive, my NAS Synology.
            Rip to your local ssd drive, then try the conversion.
            • S80_UK
              • Dec 2010
              • 25
              Forgive the obvious question, but what tool did you use for editing the tags? It seems possible that this step could have introduced the error.
              I use MP3Tag for this purpose (with FLAC files from dBpoweramp) and I have never had issues with subsequent codec conversions including from FLAC to Apple Lossless.
              • Cyrille81
                • Nov 2021
                Sorry for the delay to answer. So I did a new rip of the CD on my SSD drive of iMac and did a conversion without any issue. In second test, I tried to edit the Tags of the FLAC files ripped from the CD and after that I did a conversion into ALAC without any issue too. So the issue seems doing it from my NAS drives instead of local SSD that could introduce some issues to the files when edition the tags. Thanks for your help and answers. I configure tools to do on SSD and will see in the future if it continues to work as expected without any issue.
                To edit my tags I'm using the tags editor from PerfectTunes developed by illustrate too, as dbPoweramp. So it seems the issue is more related to using my NAS directly instead of local SSD drive to rip the CD, update tags and convert when needed.
