AccurateRip submission problem
  • Wayne
    • Aug 2002
    • 1254
    There appears to be a bug with the latest release of dMC (release 10.1) which prevents the submission of AccurateRip results. It completely ignores the option when selected.
    I have checked and the previous release 10 version works.
    Wayne
    • 46171
    Re: AccurateRip submission problem
    That function was upgraded, visit www.accuraterip.com and download the new accuraterip function dll.
    • Wayne
      • Aug 2002
      • 1254
      Doh! I hadn't realised that the function was now a separate download. I thought it was part of the AccurateRip DB itself.
      thanks,
      wayne
      • Wayne
        • Aug 2002
        • 1254
        Just downloaded and installed the AccurateRip function. Still doesn't open the AccurateRip submission window though it will open the AccurateRip results window.
        Any ideas? How can I ensure that I have the most up to date version of the function?
        Wayne
          • 46171
          Appologies, I have now uploaded the correct AccurateRip Function, download here:
          • Wayne
            • Aug 2002
            • 1254
            I have attempted to downloaded and install the latest AccurateRip function but I am still having the same problem. Before attempting the download I did clear down the cache.
            Is there anyway I can check I have the most up to date version?
            Wayne
            P.S. Have you thought of updating the dMC configuration window so that it displays information about AccurateRip in a similar manner to Sveta and the codecs?
              • 46171
              Good idea, if you look at C:\program files\illustrate\dbpoweramp\accuraterip.dll
              It should be 1.0.5
              • Wayne
                • Aug 2002
                • 1254
                The version I have installed is 1.0.0.2. I'm beginning to wonder if the problem is to do with my ISP provider and their proxy server. Instead of fetching the download from your page it could be supplying me with the version I downloaded earlier in the week.
                Maybe I'll leave it a few days and try later. Fortunately I'm not planning on ripping any CDs at the moment and I haven't any new ones to populate the database with.
                Wayne
                  • 46171
                  I have tried to download and install, it comes out 1.0.5 on my laptop.
                  • Wayne
                    • Aug 2002
                    • 1254
                    Problem solved. :D
                    As I suspected it was a proxy server causing me to continuous download the old version of the file. When I looked at my Internet settings I found an proxy option which when I turned it off ensured that I now have a copy of the latest AccurateRip function.
                    Wayne
                    BTW How do you add pictures to postings? Do they have to be on the web somewhere?
                    • Razgo
                      • 2532
                      yes.
