Audio CD Input tells me to insert Audio CD
  • Christopher
    Hello,
    Don't know why but dBpowerAmp - Audio CD Input tells me to insert Audio CD. The registery setting for auto play is
    set to (1) and dMC configuration is set to 2000/NT Built-In (Limited), but it still tells me to insert Audio CD. I'm using
    XP Pro.
    The only way I am able to copy a cda file from a CD is to use the Music Converter - CD Audio file type setting. Then
    then shows the tracks on the CD, I then copy it that way, so dBpowerAMP work using this method, but isn't Audio
    CD Input supposed to do this for me?
    Thanks if anyone can help me on this one.
    Christopher chrisatrax@yahoo.com
    Re: Audio CD Input tells me to insert Audio CD
    Sorry folks I found the reason for my problem. I have 2 roms. Had it set to the DVD rom and not Drive E.
    • Craig
      I have two ROMs and am using WinME, where is the setting so I can change the ROM?
      • Wayne
        • Aug 2002
        • 1254
        Click on the Options button within Audio CD Input. One of the options allows you to change the CD drive to be used.
        Wayne
