dBpowerAMP R17 - shell extension right click tag edit
  • Kempy
    • Dec 2018
    • 11
    just upgraded to dBpowerAMP R17, 32bit installation on Windows 10 x64.
    Right click tag edit is not working, only empty fields are shown.
    Was no problem in R16.6
    Regards
  • sylvainp
    • Sep 2006
    • 15
    Re: dBpowerAMP R17 - shell extension right click tag edit
    You have to be in the main folder where the files are stored
    Let's say you have this structure of folders: \Pat Banatar\Greatest Hits\(all the files here)
    if You right click on Pat Benetar folder it won't work
    You need to right click on the Sub-folder "Greatest Hits"
      • 45572
      For which audio format?
      • Kempy
        • Dec 2018
        • 11
        It is independent from audio format. It does not work for flac, dsf, mp3, aac seems to be a general problem with the shell extension. Example attached
          • 45572
          The issue seems to be in passing the filenames to the tag editor. You are using Windows File Explorer?
          Why did you install the 32 bit version?
          • Kempy
            • Dec 2018
            • 11
            That happends in Windows Explorer and Speedcommander 16 x64. I use the 32-bit version in Windows 10 x64 because of the VST support in the 32-bit version.
            I had the same installation, 32-bit version on Windows 10 x64, for dBpowerAMP R16.6 and right click tag edit was never an issue.
              • 45572
              As a test uninstall dBpoweramp, then install the 64 bit version please. Does that work? then try the 32 bit version again and let me know please.
              • Kempy
                • Dec 2018
                • 11
                I did as adviced above an can confirm that in the 64-bit installation the right click tag edit does work as expected, but after going back to the 32-bit installation the problem occured again.
                  • 45572
                  Noted will test for this.
                  • hvaleton
                    • Oct 2010
                    • 9
                    Regards
                    I have exactly the same problem, also with 32bit dbPoweramp R17 on Windows 10 x64.
Name:	empty fields in ID tag editor.JPG
                      • 45572
                      All fixed in R17.1, see the testing section of this forum (it should go full release in about 3 weeks).
                      • Hitarth
                        • Sep 2017
                        • 220
                        hi,
                        will this be free after upgrade to v17 ??
                          If you have paid to upgrade to R.17, all subsequent R.17.x release are free.
                          • Hitarth
                            • Sep 2017
                            • 220
                            many thanks, appreciate your reply
                            STAY SAFE !!
