Why is flac level 5 recommended when level 8 make the file more smaller?
Flac compression level 5
Re: Flac compression level 5
in my own case I use 5 compression.Comment
I have used level 8 for everything since I first started using FLAC. I have never had any problems. So, I see no point in wasting disk space (especially since I only have 653 GB left on a 4 TB drive).
MikeComment
All friends and work colleagues that I know of use the default setting, except one who uses Uncompressed...Comment
Interesting to know Gary. All seems good with the Squeezebox Touch, but I probably had later firmware before trying level 8.Comment
It was an odd problem. Never affected the TOUCH, only the Transporter. (And new firmware cured for the Transporter too). Can't recall what was actually causing the problem (and not sure I would understand the underlying technicalities in any case).Comment
