Problems with Ogg
    Problems with Ogg
    Hi I have a small problem with reading ogg files to encode em to say wav , it keeps saying that I need to install a ogg codec , I have installed both from the website (I have a P4)..
    Im a wee bit stubbed on this
  • Wayne
    • Aug 2002
    • 1254
    Re: Problems with Ogg
    Did you install the ogg codec into the same location as dMC? If you launch the dMC Configuration window you can check to see if it has recognised the codec as being present?
    If not, I suggest that you uninstall and then reinstall it into the same location that dMC is held. All mine are held in the folder C:\Program Files\Illustrate\dBpowerAMP\Compression\
    Wayne
