Is A Standard Default "Output To" Setting Possible?
  • sjf99
    • May 2019
    • 24
    Maybe this is a simple question, not sure and I tried researching on the website help area (to no avail) before I posted this so I apologize if the answer is contained. Is there a way to default "Output To" to "Existing Source Folder(s)"? Seems for me it usually defaults to "Music\Source Path\Source Filename".
    Thanks in advance.
    Scott
    • 46223
    Re: Is A Standard Default "Output To" Setting Possible?
    Once you have set it once, it should always stay the same. If it defaults back to the default value then you have security software which is stopping dBpoweramp from saving it's settings.
    • sjf99
      • May 2019
      • 24
      Thank you, I will investigate my security profile further.
