FLAC to ALAC - 16 bit 44.1 khz to 16 bit 48khz Conversion - How Bad Did I Screw Up?
  • sjf99
    • May 2019
    • 24
    All,
    I am new to dBpoweramp but plan to start using the music converter and perfecttunes software soon for my music needs (recently been using mediahuman audio converter which I liked too).
    Here is my issue were I could use some guidance. In the beginning, when I was newer to the concept of burning cd's and digital copies and also converting copies I admit to being a little naive and not as experienced. For my CD's I burned to my iTunes library as straight ALAC 16 bit 44.1khz, and will hold up to the accuraterip verification process (as I have tested a few within perfecttunes). So, all good there,no issues.
    However, in any FLAC files I may have had at 16 bit and 44.1khz I converted those to ALAC 16 bit and 48khz. Can't remember why exactly, maybe something I read about the extra "headroom" being good? Not sure, but I did this for a lot of musical pieces thru the last couple of years. I realize now, that can cause rounding issues? And potential poorer musical quality (in essence upconverting)? (Obviously as I found too it won't pass an accuraterip as it isn't the same lossless quality as a CD).
    So, my question is this, how bad of a "poorer sounding element(s)" have I potentially introduced? Is it worth going back and re-converting those files (which will be a fairly large undertaking) to get a more "accurate native source based one-to-one conversion 16bit, 44.1khz"? Or am I getting way too concerned about this? Any advice would be great. Especially if some think it good to re-convert and how to efficiently do that using dBpoweramp music converter.
    Yes, plan to stay with iTunes for the fore-sable future.
    Thanks, I fear my inexperience has gotten me into some trouble.
    Scott
    • 46370
    Re: FLAC to ALAC - 16 bit 44.1 khz to 16 bit 48khz Conversion - How Bad Did I Screw U
    Each time you change frequency, even up, you lose a little sound quality. Going back to 44KHz would lose some more. Do you have the original untouched FLAC files?
    • sjf99
      • May 2019
      • 24
      Fortunately I do have all the original flacs, I never deleted the original source.
        • 46370
        Delete all the alac files and reconvert.
        • sjf99
          • May 2019
          • 24
          Thanks. I am assuming on the re-rips, verifying them with accuraterip being successful, will be a good, strong test that everything is legit going forward then?
            yes.
            and on your ALAC conversions, you mention having the FLAC files. So you just need to delete the ALAC and use the FLAC files. No conversion necessary. And you can use PerfectTunes to check the existing FLAC files for AccurateRip match.
            • sjf99
              • May 2019
              • 24
              Alas, I still like iTunes, so if I stay here I would have to still convert. Thanks for the confirmation on accuraterip.
                got it. Just batch convert using dbpoweramp to ALAC 16/44.1. dbpa converter can automatically transfer all your tags and album art to the newly created ALAC files. And easy enough to do all your FLAC files in one batch with only a few mouse clicks (assuming the files are all contained within on parent directory structure).
                • sjf99
                  • May 2019
                  • 24
                  Thank you for your help. I really appreciate it.
                  • sjf99
                    • May 2019
                    • 24
                    Sorry Garym one more quick question about re-converting. I should start with the fresh FLACS again and not try to reconvert the existing ALACs in iTunes back to 44.1 correct?
                      • 46370
                      Correct, remove all ALAC files and convert FLAC to ALAC
                      • sjf99
                        • May 2019
                        • 24
                        Thanks again, have a nice weekend.
