Problem with FLAC streaming if DBpoweramp is installed
  • Tigerman
    • Mar 2005
    • 157
    I have a Pioneer vsx-824 receiver and under Windows 10 64bit I was able to send mp3/wav and flac-files with WMPDMC.exe (by rightclicking on a flac-file and choose 'play on device' (I hope that's the correct English translation of the name on my Windows) to the receiver which would play the flac files.
    After installing DBpoweramp, I can't stream the flac-files anymore. MP3- and wav-files play without a problem but with flac-files it tries to make connection to the receiver but it never starts.
    After uninstalling DBpoweramp I can stream flac-files again. I have this with v16.5 and v16.6. I have not tried earlier versions of DBpoweramp.
    I have tried this on 2 pc's and both can't stream flac-files when DBpoweramp is installed.
    What can I do to get flac-streaming working and have DBpoweramp installed at the same time?
    "Happiness is nothing more than good health and a bad memory."
    Albert Schweitzer (1875 - 1965)
    • 45835
    Re: Problem with FLAC streaming if DBpoweramp is installed
    Try disabling the thumbnail and property handler in Advanced Setting (dBpoweramp control centre)
    • Tigerman
      • Mar 2005
      • 157
      Thanks! It works again!
      Can you explain why mp3 and wav-files could stream, but flac-files not?
        • 45835
        Microsofts streamer must be requiring a special attribute for FLAC which they themselves supply.
