Slow conversion rates
  • rwjack
    • Jun 2002
    I have been getting really slow rates ripping from CD to WMA at 192 bit rate. dBpoweramp starts out at around 16X, then drops to 1.5X, or sometimes to .5X. It takes 2-3 hrs. to rip one cd to my Rio. It hasn't always been this slow. It occurred after one or two updates ago. I use dBpowerAMP, Power pack, and Sveta. Any advice? Thanks.
    Re: Slow conversion rates
    Try ripping to wave on the Hard disk, what speed is it?
    • rwjack
      • Jun 2002
      Still rips at 0.5.
        Check on Options that the ripping speed is maximum, if still have a program, look at Support (above) >> CD Input there is a drive speed program you can download.
        • rwjack
          • Jun 2002
          Windows Media Player rips to WMA from CD at the expected rate. Any other ideas?
            Support (above) >> dMC CD Input there is a drive speed program you can download to set the Ripping speed of your drive.
