Basic Tutorial for using Converter
  • wdesbrow
    • Feb 2015
    • 50
    (this is the first of two newcomer questions -- both involving Converter &*8230; I will enter the second in a separate post...)
    Does anyone know of a simple, step-by-step tutorial on using Converter?
    Thanks all, very much!
    • 46167
    Re: Basic Tutorial for using Converter
    The help file details using the converter on a step by step basis, either using Batch Converter or right click >> Convert To.
      • 46167
      Install dBpoweramp Music Converter, visit codec central and install DSD codec. Right click on DSD file >> convert to >> select the encoder as Wave and click convert.
