Quick Help with converting flac, Thanks!
  • yaeger12
    • Dec 2003
    I downloaded the codec but it keeps telling me that the corredt codec could not be opened each time I try to convert a flac to wave. Any Ideas where I am going wrong?
    Re: Quick Help with converting flac, Thanks!
    Make sure you install the Codec to the same location as dMC. Then look in dMC Configuration to make sure it is recognized.
      I have started all over and first I downloaded the converter and then the codec. The converter is just on my desk top, where and how do I download the codec to the same place. Sorry probably seem slike a pretty dumb question, a little new at this. Thanks for any help
        It should default to the same place, if you look in the Configuration program after installing it you can be 100% sure it has taken.
