Help - No sound in MP3 converted by DMC...
  • JLQ
    I just installed DMC.
    All works fine, without any error message. But when I try to read the MP3 file, both Windows Media Player 9 and Real Player play the song without any sound....
    Other MP3 are ok. Just the MP3 converted with DMC have this problem.
    What's wrong ???
    Jean
    Re: Help - No sound in MP3 converted by DMC...
    Try selecting a preset (on advanced) 'alt preset standard'
    • JLQ
      Hello
      Thanks for reply. No, it doesn't work. File has normal size, no error is displayed but it contains only silence....
      Jean
        Found the solution. Conversion doesn't work with my DVD-CD reader. But it works using my CD-Writer (Plextor) to read the "source" Audio-CD!!!
        Why ? I don't know. My DVD-CD reader isn't an old one.... And I can extract tracks using it with Nero....
        Jean
