ARRANGE AUDIO does noe understand IFCOMP in R16.
  • ivar
    • Mar 2015
    I cannot use IFCOMP and IF!COMP in dynamic naming in ARRANGE AUDIO codec 64-bit in R16. Compilation tag has changed from O/1 to a pull down menu where you can chose YES or NO.
    all items are renamed as if it is not a compilation.
    I have used dbpoweramp for many years , so I know it worked in earlier versions.
    I use my own naming formula, but it does not work in dbpoweramp standard either
    [IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][]\[album]\[track] [artist] - [title]
    Can anybody help?
    Ivar
    Re: ARRANGE AUDIO does noe understand IFCOMP in R16.
    In dBpoweramp the Compilation tag = 1, if album is a compilation or the tag is removed/deleted, if album is not a compilation.
    The Yes/No drop-down is just a new display/selection feature.
    If Yes is selected, Compilation = 1 (and Yes is displayed in Edit ID-Tag), if No is selected Compilation tag is removed.
    ... just tested [IFCOMP][] and [IF!COMP][] functions using Arrange Audio R4 in dBpa R16.3 Beta 5 [64-bit]. The results were as expected, so I found no problems with either function.
      Are you referring to the Naming string in CD Ripper?
      I have just ripped a compilation CD and the [IFCOMP][] function worked fine.
