dbpoweramp uninstall problem
  • jcw8705
    While attempting to uninstall dbpoweramp the uninstall removed my desktop. I am using Win98 and had GoBack which I used to revert to a previous time. I then attempted to uninstall once again (thinking it was perhaps a different problem), but that time also it uninstalled and took my desktop with it. Is there a patch that will fix this problem?
  • Razgo
    • 2532
    Re: dbpoweramp uninstall problem
    i remember this being a setting in dap a long time ago. but this should not be happening now. what version of dap/dmc are you using?
    Spoon might have to clarify this one.
      The very soon to be released R10 fixes this.
        Under version it listed 4.0.0.52 dbpoweramp Converter.
        John
          Only 6 major versions out of date...
            It is from the cnet download dmc-r9.exe.
              Sorry my mistake, R9 must have the problem - R10 very soon (finsihing the help file).
                [ QUOTE=jcw8705]While que procuraba al dbpoweramp del uninstall el uninstall quitó mi tablero del escritorio. Estoy utilizando Win98 y tenía GoBack que invertía a un rato anterior. Entonces procuré al uninstall de nuevo (el pensamiento de él era quizás un diverso problema), pero ese vez también uninstalled y tomó mi tablero del escritorio con él. Hay un remiendo que fije este problem?[/QUOTE ]
