Need Help Converting DSD files (.dsf) To FLAC Using Mac
  • nicoff
    • Nov 2014
    Is it possible to convert "dsf" files (extracted from SACDs) to FLAC using a MAC?
    I noticed that DBp can do it on a Windows machine but not sure if possible on a MAC.
    Thanks!
    Re: Need Help Converting DSD files (.dsf) To FLAC Using Mac
    Yes it can.
    • pacoinmass
      • Feb 2016
      • 30
      Yes it can.
      Spoon,
      Can you pls provide instructions on how to do so? I have the Mac version of DBp and had purchased the Windows version to convert DSD files to FLAC. I would prefer to use my Mac if possible. My current Mac version is 15.8. Thx.
      Pacoinmass
        R16 can do this on the MAC.
        • pacoinmass
          • Feb 2016
          • 30
          Ok. Thx for the quick reply.
