'Convert To' and 'Edit ID Tags' not showing up on right click
  • bart845
    Hello,
    About a week ago I noticed that the options to convert and edit ID tags from Music files does not show up anymore when rightclicking on a file.
    I've tried to turn it off and on again in the advanced configuration screen of dBpoweramp but this did not solve the problem. Also restarted multiple times. But this also did not change anything.
    I don't know if this is known bug that can happen. Please advice what to do to solve this.
    Underneath a picture of the settings and that the options are not showing:
    Regards
    • 46370
    Re: 'Convert To' and 'Edit ID Tags' not showing up on right click
    Uinstall dBpoweramp, reboot windows (full shut down), then reinstall.
    Note if you have too many items in the right click menu, Windows selectively chooses not to show certain items.
    • bart845
      Hi, That seem to have solved it. Thanks!
