output to not function right
  • Marc999
    • May 2017
    Hi, if I select output to Existing source folder(s) this option is not selected but 'source drive :\source path\source filename' gets selected. With the workaround by selecting Single folder I can select the existing folder. Because the function used to work in the right way, I re-installed 16.2 but it does not help. Besides this bugfix I would also like to know if it possible to set the option output to Existing source folder(s) as a default. Thanks in advance for all help.
    Re: output to not function right
    This is output to the existing source folder.
