How to load saved DSP effects incrementally to add to, not replace existing settings?
  • Analytic
    • Apr 2010
    • 14
    [Using R16.1]
    Is there any way to load saved DSP effects incrementally so that already loaded/set effects are not replaced entirely? For example, say I have Multi-CPU, Resample, and ID Tag Processing loaded from a particular file. And now, I also want to load a particular Graphic Equalizer setting from another file to this existing list.
    If there is no way currently to do this, can you consider adding it? For example, a checkbox in the file open dialog or holding down the Shift-key while selecting the Load, etc?
    • 46370
    Re: How to load saved DSP effects incrementally to add to, not replace existing setti
    It is not possible sorry.
