Problem editing tags
  • RossRoy
    • May 2003
    • 403
    I am in the process of ripping my CD collection to FLAC. I just noticed I made a mistake in the album name of a couple files, so I want to use the Edit Tag option to edit them, but it's a no go.
    I right click the file, it reads the tags fine. I do my modification, then click ok, half a second later the Edit Tag window disapears, so I check the file thinking the tags must've been updated, well they've not!
    The FLAC files were ripped using EAC 0.95 prebeta 3 using FLAC v1.1.0 command line. I'm running Music Converter release 10 beta 3 with PowerPack release 3 registered.
    Re: Problem editing tags
    Just check that the popup info is not the old one, ie hold the mouse over another file, then the one you have changed.
