Distortion in FLAC to WMA conversion. Solution?
  • WJMad
    • Sep 2016
    Dear fellow dBpoweramp users,
    I have recently converted some FLAC files into WMA Lossless, using the codec for 9.2. When I listen to the WMA files, each one has one moment of distortion: some have a single, small pop, while some have one or two seconds of really warping sounds (nearly as bad as an old 56k telephone modem). Meanwhile, the original FLAC files are perfectly fine - it is only the converted WMA files which seem affected. Moreover, it seems as though only files at 48KHz and 96KHz, 24-bit, are affected; 44KHz at 16-bit files seem fine.
    Have any of you ever seen this before? Do you have a solution, or a suggestion as to the source of the problem?
    Do please let me know. Thank you!
    - WJM
    Re: Distortion in FLAC to WMA conversion. Solution?
    I can't answer your question, as this *shouldn't* be happening.** But I'm curious as to why you need WMA files. Sort of a dead codec and there are lots of players that run on windows that play FLAC files. Again, just curious.....
    EDIT: **I say it shouldn't, but then again, I realize you're talking about hires files, and there are some weird things about WMA hires files based on things I've read....never been a WMS user.
    • WJMad
      • Sep 2016
      Dear garym,
      I agree, this shouldn't be happening, and it's certainly never happened to me before moving to this new laptop (which otherwise has no issues, that I know of).
      I've just converted another album (96KHz, 24 bit), and one of the tracks has distortion, again. I re-convert it from the FLAC file (which is fine), and it reappears in the same spot... The other 18 tracks are unaffected, but that one just won't budge.
      - WJM
