dBpoweramp Reference R16 re-installation
  • ExtremeGamerBR
    • Jul 2016
    • 13
    Re: dBpoweramp Reference R16 re-installation
    Try using multi-encoder first with wave as the only encoder added, then if that works add flac as the only encoder in multi-encoder.
    In this way it works perfectly.
    And I noted another thing: My error only happens when I convert to FLAC trough my Profile. If I just select FLAC it works.
Name:	Sem título.jpg
    What is wrong?
      • 44034
      What is your profile called? the image suggests that no profile is selected.
      • ExtremeGamerBR
        • Jul 2016
        • 13
        I selected the profile through the Batch Converter:
        When I click "Convert" opens the window of my other post and I can't convert.
        • ExtremeGamerBR
          • Jul 2016
          • 13
          [ATTACH=CONFIG]1061[/ATTACH]
          Any news about my problem, man?
            • 44034
            On testing it seems to be an issue if the encoder is not changed, so when music converter appears, change the codec to wave, then change back to flac, this has to be done only once.
            • ExtremeGamerBR
              • Jul 2016
              • 13
              #21
              Thanks! Now it is working! :D
